How do I add anchor links to articles? | Community
  • October 13, 2020
  • 6 replies
  • 565 views
Ho do I create a link which leads to a certain section of a collection? Like this link for example: https://www.intercom.com/help/en/collections/2091449-sending-messages-and-building-smart-campaigns#sending-messages-with-intercom/p>
I would like to know how it is possible for me to create a link which leads a customer to a particular section in the collage. Would it be possible to get instructions on how to create such links? Thank you!
Note: The Helpcenter isn't published yet so the collections so called ID's is still unknown. By ID's I mean this: https://www.intercom.com/help/en/collections/2091449-sending-messages-and-building-smart-campaigns#sending-messages-with-intercom
Another question, how is that ID defined?
Best answer by Sara T
Yayy! I solved this by myself 😀 Here's instructions if someone else is wondering the same:
First: Helpcenter doesn't need to be published to see collections so called ID's. The ID of each collection can be checked from the workspace (Article-view) directly. Just navigate to Articles -> Help Center and click collection name -> the ID can be checked from the page URL.
The link which leads to some certain section in the collage contains following parts. I'll use https://www.intercom.com/help/en/collections/2091449-sending-messages-and-building-smart-campaigns#sending-messages-with-intercom as an example URL.
  1. Start with the help center URL / domain. You can check this from the Help Center Settings. In that example above the URL is https://www.intercom.com/help/
  2. After the URL add the language of the collection, for example en/
  3. Then add collections/collection ID-collection name#section name, like /collections/2091449-sending-messages-and-building-smart-campaigns#sending-messages-with-intercom. In that example "Sending messages and building smart campaigns" is the name of the collection and "Sending messages with intercom" is the section's name. Remember to use key - to separate the words.
  4. The URL which leads to certain section in the collection is now ready :) If the helpcenter is already published you can easily check is the URL working
  • October 13, 2020
  • 1630 replies
  • October 13, 2020
Nice job sorting this yourself, @sara t​! Thanks so much for sharing the solution with the community so that others can learn from you 🙌
Kevin Bendixen
And regarding the link to a specific section of a collection here's the solution:
helpcenter-URL/collections/Collection-ID#Section-name
https://www.intercom.com/help/en/collections/2091449#sending-messages-with-intercom
Thanks @sara t​ . I didn't know this. My solution to it in the past was to publish, and then quickly unpublish so that I can get the ID 😬 Your way is cleaner!
  • 1630 replies
  • January 15, 2021
Hey @kevin b​ @mohamed e11​ @sara t​ - some great news! We've shipped this as an official feature of Articles! You can read more about it here.
That's great to know, @eric f11​! Thank you for the update :)
