How to configure SSL for you Articles Help Center custom domain using Google Cloud | Community
  • January 19, 2022
  • 257 views
The developer docs explain how to set up SSL for a Help Center using Cloudflare or AWS (CloudFront). However, we really wanted to use Google Cloud for this since the rest of our product (GQueues) is built on that platform. We couldn’t find any documentation on how to do this so I spent a few days diving deep and figuring this out.
The process is rather involved, so I decided to write up all the steps in a blog post in case anyone else is setting up SSL for their Help Center and also wants to use Google Cloud.
Here it is, with all the details explained:
https://www.gqueues.com/blog/how-to-configure-ssl-for-your-intercom-help-center-custom-domain-with-google-cloud
Hopefully this saves you some time! And if you get stuck on any step, feel free to reply – I’m happy to help troubleshoot 😀
Best answer by Eric Fitz
That's awesome, @cameron h​! Thank you so much for sharing 😄
  • January 21, 2022
  • March 16, 2022
@cameron h​ - just wanted say a huge thank you for the article. Worked perfectly for me and saved me a lot of time!
  • March 16, 2022
Terrific! So glad it helped, @cloudfit​!
