Please how do i setup intercom using the expo intercom plugin | Community
  • June 3, 2022
  • 160 views
I'll really appreciate any help.
Best answer by Daniel M15
Hey @kaapo​ ! Daniel from Customer Support Engineering here 🔧
There is an unofficial plugin that you can use to set this up, with configuration and installation documentation on the repository. Please note that this plugin is not developed or maintained by Intercom, so we cannot provide support for installing, using, or troubleshooting the plugin. Hope this helps 😄
Daniel M15
  • June 6, 2022
  • February 10, 2024
Hello @kaapo
I have tried to integrate intercom with my expo 50 app. The intercom plugin you mentioned is unofficial and I didn’t see it’s support for expo 50 version. Probably it works with the older version.
So I wrote my own plugin and here you can have a look on it. There is also a medium link where I explained how I wrote that mod-plugin.
