Problem saving an article - "Block are invalid" "Value is not an integer" | Community
  • December 15, 2023
  • 221 views
Hey all, has anyone gotten this error message before?
I updated an article this morning with some new text and images. I navigated to what is numerically the fifth image and replaced it, but I am still getting the same error message. Never seen this before and not sure how to proceed with updating my article!
I am not even sure what the “integer” problem is/what that means.
Best answer by Shauna
Hey @User1628 👋🏼 Shauna here from Support!
I’ve gone ahead and opened a conversation with our CS team to dig into this directly for you! Someone will be in touch with you ASAP 🚀
As soon as there has been a resolution / issue confirmed; I will update this post 👍🏼
Shauna
  • January 5, 2024
  • January 5, 2024
Hi! FYI, I haven’t encountered this message since it came up - I rebooted my system and re-logged in and it seemed to go away. But definitely will flag if it comes up again.
