How to prevent bot from saving responses. | Community
Question
  • December 2, 2022
  • 12 views
I have a bot that we're using to pretty much just tag users as a way to opt-in to future communication. Every time the user opts-in, it saves that "yes" as a conversation, which we then have to delete. The bot is doing all the work of tagging the customer, so saving that conversation is just extra work.
Any suggestions on how to prevent that? I'm pretty new to intercom :)
  • 512 replies
  • December 6, 2022
Hey @user2090​ Racheal from the support engineer team hereπŸ‘‹
Although you cannot prevent the "yes" from starting a conversation, you can use follow up rules to keep it out of your teammates view. For example, you can assign to unassign and close as soon as the tag is applied:
Screen Shot 2022-12-05 at 8.25.45 PMYou may also want to use the Bot inbox, this will keep the conversation in the Bot inbox and out of your teammates view.
