Bulk delete users in Intercom | Community
  • April 26, 2023
  • 2078 views
vartan.kourshounian
Hello, I currently created a segment called Inactive Users which basically are the ones who aren’t active in the last 30 days and I have around 10K+ users that I want to directly delete permanently from Intercom.
I checked this article https://developers.intercom.com/intercom-api-reference/reference/deletecontact but since I am not a technical person, I was wondering if its possible for someone to guide me in the steps needed to get the job done.
Best answer by Daniel M15
Hey @vartan.kourshounian! Daniel from Customer Support Engineering here 🔧
To permanently delete your users, you will need to make use of the API endpoint that you’ve linked (unless you are to delete them one by one via UI, which is time consuming!), so I would recommend reaching out to a developer about using this. You can use our search endpoint to retrieve the users in your segment based off a relevant condition, and for each that’s returned, run a request to the endpoint you’ve linked above, using the Intercom ID of each user that’s returned to make the delete request. You can use the pre-populated code snippets in our documentation to achieve this.
Diana Tripac
  • April 28, 2023
Adding @Milan @Nathan Sudds @Kevin Bendixen in case they can advise on that 🙌
Daniel M15
  • April 28, 2023
vartan.kourshounian
Hello @Daniel M15 thank you for the detailed explanation.
Just to be on the same page, currently I have 16K contacts where 13K should be deleted since the last seen is greater than 30 days. Yesterday, I filtered down all of the companies by their last seen and it helped me delete couple of companies with its contacts using this API https://developers.intercom.com/intercom-api-reference/reference/deletecompany and reduce the number of contacts to 9K, however, I checked today and the same contacts/companies were reverted back and the count is back to 13K now.
I created a segments from the contacts with the filters that I need, I am just not sure how to proceed - is the delete suppose to be id by id or can I do it one time for all of them? Is there a way that I can get a ready made code snippet?
vartan.kourshounian
One more question @Daniel M15 , I am checking the companies with their last seen date and anything that is older than 30 days, I am deleting the company which is resulting in deleting the contacts found in it. But I am seeing the number of users on my saved segment is only changing, but the contacts are still found in the All Users list. Shouldn’t when I delete the users through the company to be completely deleted from the system?
