Creating a Company advice
  • August 24, 2023
  • 164 views
I understand that Companies need to be created via API, I also understand they show when they have 1 associated user - but sadly even with the Developer Hub and knowledge of sending API requests and Postman as well; I can’t get this to work at all.
For Attaching a Contact:
Why does the Body only include an ID? No company ID, user ID ever seems to do anything with this.
"id": "64e5e25c35824d3aabb0e535"
Is there a video or simple walk through that simply shows how to create a simple Company and associates 1 User; it would be really helpful as its far too time consuming.
After hours of trying, still cant create a single Company or attach one user.
Best answer by Racheal
Hey @Ian Maison  Racheal from the support engineer team here👋
To create a Company you would send a POST request to:
https://api.intercom.io/companies
With this in the request body:
{ "company_id": "company_remote_id",
"name": "my company",
"remote_created_at": 1374138000 }
When it comes to adding a contact to a company the Company ID is included in the request URL:
https://api.intercom.io/contacts/{id}/companies
This is why it isn’t in the request body. The ID in the request body must be the Intercom defined id representing the Company, as mentioned here.
I hope this helps!
  • 512 replies
  • August 29, 2023
I hope this helps!
