Can I set up away mode for my teammates when they are OOO? | Community
  • February 2, 2023
  • 200 views
Best answer by Lisa B11
Hey @lisa b13​ 👋
Yes, you can now set up away mode if your teammates are out of office, you can do this in Settings > Inbox Settings > Automatic Away Mode 👇
Screenshot on 2023-02-02 at 08-52-36Hope this helps 🙌
  • February 2, 2023
Hey @lisa b13​ 👋
  • January 25, 2024
Does this require specific upgrades, when I go into settings as an Admin these options are not listed.
  • January 26, 2024
Hi @JenM -- Cam from the Intercom Support team here.
At present, access to the Automatic Away Mode feature is only available on certain subscription packages - if you see the “Get feature” button and details when you land on the page then yes, there is an upgrade that you’ll need to action. You can click on the purple “Get Feature” button to see the details around what type of upgrade would be needed (clicking on the button doesn’t immediately opt you into or action anything just in case thats a concern👍)
Hope that helps!
