Auto-Reply: as solution for no signature feature. | Community
  • August 5, 2021
  • 6 replies
  • 123 views
Hey guys,
we are a german based company, in e-mails we are comitted to post our company details to emails. There is no Signature-Feature in Intercom, so we tought about a workaround.
The workaround would be:
  1. Get Message from Customer per E-Mail
  2. Intercom send an auto-reply [JUST FOR E-MAIL Conversation]
    1. Text would be like: We are currently very busy and write you as soon as possible. [Now our company details, that are required from german law.]
  3. From now on, we dont send any company details, but we had it in the first response, so the law-situation is fine.
Any ideas how to set it up, that every FIRST Message via EMAIL get an AUTO-REPLY?
Thanks for help!
Andreas!
Best answer by Kevin Bendixen
@andreas b12​ Would it be enough if all of your outgoing emails from Intercom had a signature? You could simply create a custom email template where you could include a signature in the footer element. You can then select this template to be the default one for all emails.
Kevin Bendixen
  • August 5, 2021
You wrote its for outgoing e-mails. I found the feature, but it is on "Outbound". - Does the template also works an alle via Messenger sent e-mails? Thats our point, need it for the outgoing e-mails by answering questions in messenger.
Thanks for your help!
Kevin Bendixen
@andreas b12​ yes, if you choose the template as the default it will also be used when you respond to an email via the Intercom inbox.
  • August 6, 2021
Good Morning Kevin.
Thats wrong, tested it right now, its not working. The Template I designed and choose not displayed on the respond email via intercom inbox.
Kevin Bendixen
@andreas b12​ Then there seems to be a misunderstanding of what you are trying to do. Because I just sent an email to myself via the Intercom messenger using this button and it did use the default template I set.
Bildschirmfoto 2021-08-06 um 16.31.36Can you explain what exactly you want to do?
Or are you talking about the "reminder" emails that Intercom sends if a user hasn't seen your chat response?
  • February 16, 2022
Hey there.
We've got the same problem and the proposed solution doesn't work.
How can we add a footer to the following email generated by replying to a conversation in Inbox?
Screen Shot 2022-02-16 at 13.30.59
