Can I integrate Trustpilot with Intercom? | Community
  • September 3, 2020
  • 558 views
Has anyone integrated Trustpilot reviews with intercom i.e. we'd like the reviews to b fed straight in to the intercom inbox?
Best answer by Beth
Hi Mike,
Thanks for reaching out here! There's currently not way to integrate Intercom and TrustPilot via the UI; however, you can use TrustPilots API here and Intercom's API here to set up your own custom integration. This would require some dev muscle but someone with API knowledge should be able to set something up for you.
  • 42 replies
  • September 3, 2020
Hi Mike,
