How to manage conversations re-opening without overwhelming the Inbox | Community
  • August 17, 2023
  • 735 views
Hello! Looking for a bit of advice.
Our team has a lower inbox volume (around 40 a day) and the inbox is usually 60% email and 40% chat. At the moment, any messages that come in we close after our response and only snooze conversations that need a follow up at a later time. This has helped us keep a clean inbox that is easy to see what conversations need to be attended to.
However, this causes some problems when we want to track CSAT and time to close, so we are looking to change how we are working in Intercom.
I know there are automations you can set up that will automatically respond to chats if they customer has not followed ups but I am more concerned that we will have tons of emails re-opening that will create more work for us manually to follow up with customers since emails are our main channel for conversations. As well, if I do set an auto-reply when a conversation re-opens - what is there are conversations that shouldn’t get that auto-reply. Do you tag them a specific way?
Curious to know how other teams are managing re-opening conversations while keeping the main inbox clean. There is only two of us covering support (1 on any given day) so managing the volume of tickets is extremely important to our bandwidth as a company. Do you have the re-opened messages open in another view and follow up with them all at the end of the day?
Any advice would be very helpful! Thank you
Best answer by Milan
Hello @Amber - to set some background first - I never worked as a support person or was heading the support team, but I worked with them as an Intercom expert. And all my clients have different ways of work, but some general rules/tips that you might find useful are:
  • Differentiate channels - you said you have 60% email and 40% chat. Intercom Workflows have ability to differentiate conversations based on the channel and to set a different activity. Also, for chats you would probably like to have autoresponders or Custom Bot that will try to help user self-serve himself or to gather relevant info and then connect it to the relevant team.
  • Prioritize chat over email - with Workflows it is easy to do it. I have clients who even create separate Teams and/or Views in inbox based on the channel and deal with the chat first.
  • Automate but do not over do it - Workflows can help you a lot but remember there will be always some special cases and if you set up a lot of workflows that should close the conversation based on the content there might be some that can might be wrongly closed.
  • CSAT and other metrics can be filtered out based on channels!
Hope some of this helps!
Cheers!
Shauna
Forum|alt.badge.img+6
  • August 18, 2023
Adding @Milan , @Nathan Sudds & @Kevin Bendixen in case they can advise on this 👌🏼
Milan
  • August 18, 2023
Cheers!
  • August 18, 2023
@Milan Thanks for your reply. In your Experience how do teams handle messages re-opening? Do they have a separate view for that?
Milan
  • August 18, 2023
I do not remember anyone treating this separately in the View section - and I just briefly looked at the Views settings, and I do not see straight-forward way how to separate those conversations that are re-opened into one view. I could probably set some workaround for this but, as already said, I’ve seen clients treating it the same other conversations.
Landon Bennett
You may want to try out Bump which is an app on Intercom that lets you automate follow-ups to conversations where you don’t have a resolution. I was the previous founder, but sold the business in early 2021. I can’t vouch for the product or service at this point, but it may work for your needs here.
