Intercom Android SDK Crash | Community
  • April 8, 2025
  • 7 replies
  • 630 views
Hi! I'm using Intercom Android SDK 15.15.0 and i caught a crash. The crash happens if you go from the home screen to an empty chat screen -> start a new chat -> send any message -> quickly go back to the home screen -> and press the "Send message" button before the home screen has updated. This sequence of actions leads to a crash with the following logs:
java.lang.IllegalStateException: The specified child already has a parent. You must call removeView() on the child's parent first.
at android.view.ViewGroup.addViewInner(ViewGroup.java:5601)
at android.view.ViewGroup.addView(ViewGroup.java:5387)
at android.view.ViewGroup.addView(ViewGroup.java:5327)
at android.view.ViewGroup.addView(ViewGroup.java:5299)
at androidx.compose.ui.viewinterop.AndroidViewHolder.<init>(AndroidViewHolder.android.kt:99)
at androidx.compose.ui.viewinterop.ViewFactoryHolder.<init>(AndroidView.android.kt:332)
at androidx.compose.ui.viewinterop.ViewFactoryHolder.<init>(AndroidView.android.kt:323)
at androidx.compose.ui.viewinterop.ViewFactoryHolder.<init>(AndroidView.android.kt:342)
at androidx.compose.ui.viewinterop.AndroidView_androidKt$createAndroidViewNodeFactory$1$1.invoke(AndroidView.android.kt:275)
at androidx.compose.ui.viewinterop.AndroidView_androidKt$createAndroidViewNodeFactory$1$1.invoke(AndroidView.android.kt:274)
at androidx.compose.runtime.changelist.Operation$InsertNodeFixup.execute(Operation.kt:585)
at androidx.compose.runtime.changelist.Operations.executeAndFlushAllPendingOperations(Operations.kt:310)
at androidx.compose.runtime.changelist.FixupList.executeAndFlushAllPendingFixups(FixupList.kt:50)
at androidx.compose.runtime.changelist.Operation$InsertSlotsWithFixups.execute(Operation.kt:552)
at androidx.compose.runtime.changelist.ChangeList.executeAndFlushAllPendingChanges(ChangeList.kt:81)
at androidx.compose.runtime.CompositionImpl.applyChangesInLocked(Composition.kt:984)
at androidx.compose.runtime.CompositionImpl.applyChanges(Composition.kt:1013)
at androidx.compose.runtime.Recomposer$runRecomposeAndApplyChanges$2$1.invoke(Recomposer.kt:685)
at androidx.compose.runtime.Recomposer$runRecomposeAndApplyChanges$2$1.invoke(Recomposer.kt:585)
at androidx.compose.ui.platform.AndroidUiFrameClock$withFrameNanos$2$callback$1.doFrame(AndroidUiFrameClock.android.kt:41)
at androidx.compose.ui.platform.AndroidUiDispatcher.performFrameDispatch(AndroidUiDispatcher.android.kt:109)
at androidx.compose.ui.platform.AndroidUiDispatcher.access$performFrameDispatch(AndroidUiDispatcher.android.kt:41)
at androidx.compose.ui.platform.AndroidUiDispatcher$dispatchCallback$1.doFrame(AndroidUiDispatcher.android.kt:69)
at android.view.Choreographer$CallbackRecord.run(Choreographer.java:2357)
at android.view.Choreographer$CallbackRecord.run(Choreographer.java:2368)
at android.view.Choreographer.doCallbacks(Choreographer.java:1504)
at android.view.Choreographer.lambda$new$0(Choreographer.java:333)
at android.view.Choreographer.$r8$lambda$LnXpohGOl-DJFbamCZawNX_OpyU(Unknown Source:0)
at android.view.Choreographer$$ExternalSyntheticLambda0.run(D8$$SyntheticClass:0)
at android.os.Handler.handleCallback(Handler.java:997)
at android.os.Handler.dispatchMessage(Handler.java:111)
at android.os.Looper.loopOnce(Looper.java:237)
at android.os.Looper.loop(Looper.java:325)
at android.app.ActivityThread.main(ActivityThread.java:10361)
at java.lang.reflect.Method.invoke(Native Method)
at com.android.internal.os.RuntimeInit$MethodAndArgsCaller.run(RuntimeInit.java:635)
at com.android.internal.os.ZygoteInit.main(ZygoteInit.java:961)
Suppressed: kotlinx.coroutines.internal.DiagnosticCoroutineContextException: [androidx.compose.runtime.PausableMonotonicFrameClock@14e49ee, androidx.compose.ui.platform.MotionDurationScaleImpl@4f02e8f, StandaloneCoroutine{Cancelling}@a0d951c, AndroidUiDispatcher@adf3525]
Best answer by skid45
I believe I’ve found a solution to this issue. It seems that your code uses the composable function AndroidView. This function is exactly where the problem I described above occurs. To fix the crash, you just need to add a single line that calls the ViewGroup.removeView(view) method. I tested it with WebView, and it works perfectly.
AndroidView(
modifier = Modifier.fillMaxSize(),
factory = { context ->
SomeView(context).also {
if (it.parent != null) (it.parent as ViewGroup).removeView(it)
  • April 13, 2025
AndroidView(
  • April 28, 2025
Hi Intercom team! Just wondering — do you have any plans to fix this crash in your SDK?
Hi ​@Intercom  , Is there any updates on this ?  We hare constantly having this crash.
@Racheal Here is the same issue as here :
Can you please look into that ?
@skid45 ​@Jacek Szmelter can you please check if the issue persists in the latest version of our SDK https://github.com/intercom/intercom-android/releases.
Hi ​@mateusz.leszkiewicz . Sorry for late reply but yes it seems like the issue’s been fixed  🙌
@Jacek Szmelter I am glad to hear that!😎
