Is there a way to export conversations? | Community
  • September 19, 2022
  • 6 replies
  • 1061 views
We want to export full extracts of our conversations from our workspace - how can I do this?
Best answer by TBelevska
Hi @Shauna O12
You can export full extracts of your conversations using either Intercom's native options or the Help Desk Migration app.
Here’s how each works:
Using Intercom
You can request a full workspace export directly from Intercom. Intercom supports several native options like:
  1. Download an individual conversation via Export conversation
  2. Downlaod conversations in bulk via the API
  3. Export conversation data to CSV: Reports > Data export.
  4. Export as JSON to Amazob S3
Note
  • The data may require additional formatting if you're planning to use it elsewhere.
  • You can export conversations from the past 2 years to a CSV file.
  • Exporting to JSON offers historical and periodic export options.
Using Help Desk Migration
If you need a structured export for analysis or platform transfer, Help Desk Migration can help:
  1. Sign in to the Migration Wizard and choose Intercom as the source.
  2. Select the workspace from which you want to transfer your records.
  3. Choose a specific help desk to CSV where to export your conversations
  4. Configure the export settings based on what data you need (tickets, conversations, agents, contacts, attachments, tags, etc.).
  5. Run a free demo to preview how your data will look after export.
Tips to consider:
  • Skip attachments if you don't need them.
  • Add any tags to migrated conversations to sort them out in a target platform.
  • Choose to import your newest records in a chronological order, from most recent to oldest.
For a full extract, just let the support team know you're looking to export all conversations from your Intercom workspace. They'll guide you through the next steps.
Shauna
Forum|alt.badge.img+6
Hey @shauna o12​ 👋🏼
Using our Conversations API to extract full conversations. You'd first have to list the conversations, and then use GET for individual conversation ID's.
You can't do this through the UI - only through the API.
TBelevska
Innovator ✨
  • Innovator ✨
  • May 7, 2025
Hi @Shauna O12
Using Intercom
Note
Tips to consider:
  • July 31, 2025
It would be super helpful to be able to bulk download conversations, as opposed to by one by one...
@TBelevska  just so that I understand this fully, can you help me figure out what exactly the GET needs to have to download not just the first conversation of a user request on a JSON/CSV file, but the whole conversation end to end from the moment it was first opened on the date range? Meaning, I would like to retrieve the whole conversation, not just the first contact of this user. I also would like it to be only inbound, not outbound = showing only the user inputs/conversation. We have only managed to retrieve the first line via API. Thank you!
Just released an app that exports Intercom conversations to styled PDFs — includes metadata, attachments, participant info, and side conversations.
It's freehttps://www.intercom.com/app-store/?app_package_code=export-conversations-wtc5&search=export%20
Here it an example:
Happy to hear feedback or feature requests.
TBelevska
Innovator ✨
  • Innovator ✨
  • June 5, 2026
Hi there,
I am sorry for such a late reply.
To get the full conversation (not just the first message), you need two steps:
First, use GET /conversations with your date range filter to get a list of conversation IDs. Then, for each ID, call GET /conversations/{id} — this returns the complete thread from start to finish.
Inside that response, look for the conversation_parts array. That's where all the individual messages live. To show only user inputs and filter out agent/bot replies, just keep the parts where author.type is "user".
So in short: list conversations by date → grab each ID → fetch the full thread → filter by author.type = "user". From there, you can export to JSON or CSV as needed.
