Has anyone cracked the limitation of customers being unsnoozed in a workflow? I know that if the conversation is snoozed via the workflow, the reassignment to an agent is not possible. Has anyone come up with a workaround?
Snooze Automation to Reassign
Hey ​
You are correct, if a conversation is snoozed via a workflow, reassignment to an agent is not possible directly through the workflow. When a conversation is snoozed, it will remain assigned to the original agent unless it is unsnoozed due to a customer reply, an admin reply, or the snooze period expiring. There is no built-in way to automatically reassign the conversation to another agent upon unsnoozing within the workflow itself.
A possible workaround is to create a workflow that automatically snoozes conversations after a period of customer inactivity and assigns them to a specific inbox. However, if an agent manually snoozes the conversation, it will remain with that agent when unsnoozed unless reassigned manually.
In summary, there is no native solution to reassign snoozed conversations upon unsnoozing, but workflows can help with inbox-level assignment in some cases.
Join the Intercom Community 🎉
Login to the community
