Using API to capture Lead Data | Community
  • May 16, 2024
  • 86 views
Is there a way for Lead data to be captured using an API? I’m a little lost and wanted to see if that is even possible.
Best answer by Cam G.
Hi@Paco -- Cam from the Intercom Support team here!
Would you be able to elaborate a bit further on where you’re getting ‘lost’ and what data you’re looking to get about your Leads via API 😁? Keen to make sure I’m on the same page as you so I can get you the bets answer possible.
Data on Leads is certainly available via API - if you haven’t done so already, this page of our Dev Docs is well worth a read through as it outlines how we define the overarching concept of Contacts and the Lead and User roles that exist within it.
  • May 24, 2024
