Hi! Has anyone found a way to embed a PDF into an article (so it's readable on screen)? | Community
  • February 1, 2023
  • 280 views
Right now I see that I can attach the PDF, which creates a link that readers can click, but I'm trying to determine if there's any way to have the PDF show as an embed that they can scroll/read through directly. (See attached for what I'm looking for.)
For context: our previous documentation center consisted of these beautifully designed PDFs and infographics, and we don't want to lose them in the transfer. The only workaround I have found is to export the PDF as jpegs and then insert the images one by one...but this causes the text on the PDF to appear extremely small, to the point of being unreadable. 😞
Best answer by Joseph S.
As per my last knowledge, it's not possible to embed it unfortunately.
Joseph S.
Super User ✨
  • Super User ✨
  • 77 replies
  • February 2, 2023
