How can I display articles that are only relevant to a particular product? | Community
  • February 11, 2021
  • 6 replies
  • 305 views
I'm trying to use article rules to display only the articles relevant to a particular product. Not working as expected. Is it my rule or my Intercom config?
My article rule uses the referral URL attribute. the URLs look like this:
<product1>.<mycompanydomain>.com
<product2>.<mycompanydomain>.com
My rule specifies referral URL contains <product1>.<mycompany.com>.
Should this rule allow users coming from the product1 URL to see the article?
Hello @user892​ , I will jump into this conversation. If you are planning to restrict articles based on user products, you should send Intercom data attributes.
Example:
1) Creating Data Attibutes let's say - Product
2) Send Intercom data - Product = Product1 or Product = Product2
3) Restrict articles based on the data attribute
The Help Center URL will be one - Like Help.example.com.
When a user makes a log-in to your app and redirects to the help center, they will see appropriate articles.
Let me know if you have any further questions or need some video instruction on this case. I will be more than happy to provide all information.
Looking forward. 🦄
  • February 15, 2021
Hey @user892​, can you tell me a little bit more about how you've set up this rule? How are you sharing the articles? Is it through a chat message using the Article Inserter app?
  • February 15, 2021
Our web apps just display the whole Help Center when users click Help. Then they self help.
  • February 16, 2021
Example:
Looking forward. 🦄
  • February 16, 2021
thanks for the input. custom attributes require engineering cycles, which i was hoping to avoid. seems we will have to bite the bullet.
  • February 16, 2021
@user892​ , Are you currently tracking logged-in visitors in Intercom? How about using tags instead of data attributes?
  • February 16, 2021
not yet. help center is the primary use case right now. i inherited a help center for a legacy product. we have a new product under development.
