Is it possible to add keywords or hashtags into Help Center articles? (more visibility) | Community
Hi!
I would like to know if it's possible to add some keywords or hashtags within Help Center articles that they can be found more easily. I'd be happy to hear any other trick to increase the visibility and efficiency of articles in the way that they are found.
Thanks in advance!
J.
Hey @Josselin  and @Bianka 👋
Thank for all your feedback concerning this feature request.
I can assure you that our Product team is working on this feature to you as soon they can.
Whenever we do release new features, we'll announce it on the Product Changes page, so I'd recommend keeping an eye here
Kevin Bendixen
@josselin​ To my knowledge there is no option to add hashtags to articles.
If you want to make sure your articles are found when a user searches for a specific keyword your best option is to follow basic SEO strategies:
  • Include the most relevant keywords in the title (but make sure that it's still understandable for humans ;) )
  • Use the description of the article
  • Include keywords in H1 and H2 headlines
  • Include keywords in you ALT-Tags for images
Another thing we did is, if we find there are search terms that show no result (check your reports for that) because it's not the keyword we optimized for, we add those keywords at the bottom of the article as a code-snippet
  • October 16, 2020
Hey @kevin b​ thanks a lot for your precise answer! It's well appreciated.
Can you give me a little bit more context for your last tips regarding adding some code-snippet directly at the bottom of your articles? How do you do it exactly? I talked with a dev at Wooclap and he was a bit confused as well on how to do it properly if we understood you well.
Which article on Papershift's Help Center uses this tips for instance?
Thanks a lot already! 🙌
Josselin
Kevin Bendixen
@josselin​ Sure thing.
It sounds more complicated than it is. I'll attach a screenshot on how to do it in the editor.
Bildschirmfoto 2020-10-16 um 15.06.05An example would be this article: https://help.papershift.com/de/articles/4425440-was-passiert-wenn-du-die-mitarbeiterzahl-anderst (only the German version)
You could also add a divider at the end of the article and add more keywords, but I prefer the code-thing as it is formatted different from the normal text and so the reader won't be as confused by it.
Hope this helps.
  • October 16, 2020
Thanks @kevin b​ it's indeed what we thought but I was wondering if I was not missing something more custom/dev ;)
thanks again for considering my question. I hope all is good on your side at Papershift!
J.
Kevin Bendixen
Always happy to help.
Bianka
  • July 23, 2024
Upvoting this - I am surprised to see this was already reported 3 years ago but we can still not add specific tags / keywords.
We just recently moved our KB over to intercom and while Kevin’s code-block suggestion surely works, I don’t think it a very professional/attractive solution to add keywords with spelling error to the articles.
  • November 25, 2024
Also upvoting this as we also want a remedy to guide our users when they search for something that we have content for but perhaps not in the right language or not the right keywords. The workaround we use here is to create a collapse at the end of an article and put these keywords, or searches with no results there. This way at least the article pops up in search results yet remains unobtrusive. Since we manage HCs with multiple languages, this issue pops up more for us when someone searches for a foreign language keyword in a language that is not their own.
  • December 9, 2024
Upvoting this as well, this is a huge pain point and we find the tags under a toggle of misspellings to be an unprofessional way to workaround what should be a product-based solution
  • June 27, 2025
Need this feature desperately. It has been more than 3 years since this feature was asked, and surprised that the team still hasn’t worked on this. I don’t see any product updates related to articles in their website, too. Wondering if the team prioritizes feature updates for articles.
