Is it possible to embed an image inside a paragraph? If so, how? | Community
  • June 1, 2022
  • 259 views
Best answer by Magnus
Hey @user1260​, Magnus, a Support Engineer from Intercom's team jumping in here!
I'm not 100% sure what you mean by embedding an image into a paragraph, but I'll do my best to give an answer here.
At the time of writing, it's not possible to put images side-by-side, behind, or overlaying text in the Help Center. Each image will be on its own "line", making sure that both text and image are showing correctly in the Article. If an image is not wide enough to fill the full width of your Article, I'd recommend centering it to give it a better look.
Articles___Magnus_Example_Workspace___Intercom-2
  • June 3, 2022
  • June 3, 2022
I figured that was the case as I had read everything sent to me. This is what I was looking to do: (Something similar). Or even put it at the end - or it would be nice to be able to upload some of our own images to use as an Emoji.
