Is it possible to restrict Articles to Google or alternate external IdP users? | Community
  • June 12, 2025
  • 176 views
Patrick H12
I understand that I can change article access to only Users. This is great, but users can’t view the articles unless they search for the article via the messenger in-app. I’d like to be able to keep our knowledge base private, but be able to send a link to a user.
Am i misunderstanding how this works? If not, is it possible to add a SAML app or something to authenticate users via Google Workspace?
Best answer by Paul Byrne
Hi ​@Patrick H12 Paul here from weekend support engineering to help you out 🤝
You're right, when articles are restricted to Users only, they can’t be viewed unless the user is identified via Intercom (e.g. logged in to your app). So direct links to articles won’t work unless opened inside your app/site while Intercom is active.
Intercom doesn’t support SAML or Google Workspace login for Help Center access. Identification must happen through your app via the Messenger.
Workarounds:
  • Send article links via Intercom Messenger (if user is identified)
  • Host a separate gated Help Center that supports SAML
  • Use the Articles API to display content in your app behind login
Happy to help with any of these setups if needed.
Paul Byrne
  • June 14, 2025
Workarounds:
Patrick H12
  • June 17, 2025
Thanks Paul I figured that was the case. Gotta remember to send them via messenger more often.
Paul Byrne
  • June 17, 2025
All good, Patrick! Best to get it clarified to be sure. If you want to know anymore about the topic or anything else feel free to ask.
Always happy to help! :)
  • July 31, 2025
Am I misunderstanding how this works? If not, is it possible to add a SAML app or something similar, like how some platforms handle access for tools such as Geburtshoroskop online to authenticate users via Google Workspace?
You're not misunderstanding. By default, users must be logged in via the in app messenger to view restricted articles. To allow link access while keeping the knowledge base private, you’d need authentication outside the app. Yes, adding a SAML app or Google Workspace SSO could make that possible if your platform supports it.
