How do I create custom fields? | Community
  • October 4, 2022
  • 1309 views
I want to import from an excel file, and pull specific fields from the file into the body of an email. Much like a Word document email merge, but using Intercom.
Best answer by Daniel M15
Hey @user1352​! Daniel from Customer Support Engineering here 🔧
It sounds like you want to create a custom data attribute! You can create a custom data attribute through a number of ways, including right through the UI, and the Messenger code snippet. You can read more about how to create a custom attribute this great Help Center article. Once you've done this, the field will now be populated for your users, so you can import users from a CSV file and map whatever value you like to the new custom attribute. This attribute can now be used dynamically in Outbound messages, including emails!
I hope this helps 😊
Daniel M15
  • October 5, 2022
I hope this helps 😊
