Is it possible to delete or hide old messages sent to customers in their message center? | Community
  • January 12, 2023
  • 9 replies
  • 2569 views
When we were first setting up Intercom we had 2 people testing out features such as sending a welcome message to all customers and someone else testing the message feature by sending a test message to all customers.
Now, when a customer opens the intercom message center they see a bunch of fake messages or old welcome messages, and they don't go away. This is on EVERY customer and I didn't realize it until I took over intercom.
What if our customers use Intercom a lot? Will they just have a loooong list of conversations here?
Best answer by Racheal
Hey @ashley c12​ Racheal from the support engineer team here👋
Is there any particular reason you haven't deleted the messages in your workspace? If you delete the original Post or Chat it will also remove it from their Messenger.
I hope that helps!
  • January 12, 2023
I hope that helps!
  • January 12, 2023
Hi @racheal​ That is a great question! Nope - no reason at all! I didn't know I Can you help with this answer? "What if our customers use Intercom a lot? Will they just have a loooong list of conversations showing every time the navigate to messages?"
  • February 17, 2023
Hey Racheal,
"Is there any particular reason you haven't deleted the messages in your workspace? If you delete the original Post or Chat it will also remove it from their Messenger."
I see where you can delete the USER and their Conversation history but not just the conversations. I ran tests etc. and want to get rid of those conversations, they are closed but show up in messenger. Let me know. What am I missing?
  • February 17, 2023
Hey @greg c​
Here we are specifically referring to Outbound Posts and Chats, which can be deleted. Conversations cannot, unless you delete the user then all of the Conversations will be deleted as well. You can delete Conversation parts, but not the entire Conversation.
I hope this clarifies!
  • September 16, 2023
I have the same problem, cant dele a conversation. And it is creating a long list on user/customer side.
  • December 28, 2023
In my opinion it would be a good idea that if not all but only one week or 3 day old messages are displayed for the customer. Rather than all the previous messages sitting in the history.
  • January 23, 2024
I agree with the other users on here. That you should only show recent active conversations. Perhaps closed or resolved should be under a tab or button or inactive after x number of days.
Is there a way to delete a participant from a conversation via API?
If exists, I would keep the conversation but without the participant so the conversation does not appear.
  • May 4, 2024
Hey folks!
Just wanted to note that you can now delete single conversations in the Unstable version of our REST API. You’ll want to use the ‘Delete a conversation’ call to do that. This will allow you to set up your own customized deletion process if you don’t want your customers to have access to their full conversation history.
