Is it possible to prevent page view tracking for certain pages / installations?
  • January 27, 2023
  • 129 views
I have two different places my app takes effect: Main web and Chrome Extension
I want page view tracking in the main web app. But, I don't want page view tracking in the chrome extension installation. This is because it's implemented as an IFrame, so the page is always the same and provides no value.
The chrome extension activity is tracked by custom events, so I am still covered there.
Best answer by Joseph S.
Hi @steve b13​ ,
As far as I know, Yes, you can do it!
You can do it through using the Intercom JS API to disable the automatic page view tracking for the Chrome Extension installation, and only enable it for the main web app. You can write a JS code snippet for this and place it in the JS file that is hosted on the Extension installation and the
isChromeExtension.
Perhaps this can help as a starting point: https://www.intercom.com/help/en/articles/175-set-up-event-tracking-in-intercom/p>
I hope this helps you the slightest.
Joseph S.
Super User ✨
  • Super User ✨
  • 66 replies
  • January 27, 2023
Hi @steve b13​ ,
isChromeExtension.
  • January 27, 2023
Oh excellent! Do you know the particular API key? I read through but didn't see anything mentioning this.
Joseph S.
Super User ✨
  • Super User ✨
  • 66 replies
  • January 27, 2023
So, I took a deeper look and as i understand, for this, you will need to hide the widget launcher if it's not a chrome extension, because as per the Intercom help center if you have it, intercom will automatically count the page views
Here is a JS code snippet if you will go for it:
window.Intercom('update', {
hide_default_launcher_badge: true
I am not aware of a method to allow you to have the launcher and still separate or avoid counting the views, and I believe that sadly there is no such a way 😔 Sorry if my previous answer caused any confusions!
