Android SDK ANR on initialize | Community
  • August 14, 2023
  • 386 views
Hi, we’re running into an issue with ANRs on our application stemming from the initialize call on the Intercom SDK.
We are currently using 15.1.4 of the Android SDK with the following code used for initialization:
Intercom.initialize(
application,
apiKey,
appId
The following is the stacktrace we’re seeing in Firebase for a number of our users:
io.intercom.android.sdk.Injector.getMetricTracker (Injector.java:255)
io.intercom.android.sdk.Injector.getOverlayPresenter (Injector.java:279)
io.intercom.android.sdk.Injector.getResetManager (Injector.java:333)
io.intercom.android.sdk.Injector.getLifecycleTracker (Injector.java:311)
io.intercom.android.sdk.Injector.initWithAppCredentials (Injector.java:135)
io.intercom.android.sdk.Intercom$Companion.create (Intercom.kt:1092)
io.intercom.android.sdk.Intercom$Companion.initialize (Intercom.kt:1005)
com.<redacted>.android.util.IntercomUtil.initialize (IntercomUtil.kt:38)
When looking at the releases, we’re currently 2 patch versions behind but the release notes don’t indicate that the ANR has been resolved so I wanted to understand if this issue has been resolved or if it hasn’t been, if there is an ETA for when it would be resolved?
Best answer by Cam G.
Hi @Engineering! Cam from the Support Engineering team here.
I can see you’ve started a chat with us over in Messenger and sent through some additional details on this issue - I’ve picked up the conversation and will get back to you on this there if thats ok?
  • August 17, 2023
  • September 19, 2023
@cameron.gumley
I have a similar problem.
Inntercom SDK version 15.1.0.
Firebase Boom version 32.2.3
Did you somehow manage to fix this?
  • November 3, 2023
Hi @Serhiy WiFiMap
I believe you’ve already updated the Intercom iOS SDK being used by your app, which has hopefully resolved this issue, but posting an answer to your question for completeness in case other community members see the same issue:
Our team released a fix for this IntercomSDK_IntercomNexusSocket resetConnectionTimeout issue on iOS which has been implemented in the Intercom iOS SDK from version 15.1.5 onwards 👍
That being said, our team is still working on this issue in relation to the Intercom Android SDK. When there is a fix released I will provide an update.
Hi  ​@Cam G.   We’re facing the same ANR issue from intercom with the later version (it’s blocking at the function onCreate on main thread), could you guys please help us take a look at this one?
One thing to notice is it mainly happens on Android 14.
We’re using "@intercom/intercom-react-native": "^8.3.0" and intercom android SDK: “15.14.0 “
