Android SDK crash | Community
Android SDK crash
  • September 27, 2023
  • 331 views
I’m using same dependencies with your sample and have the crash:
java.lang.IncompatibleClassChangeError: Found interface androidx.compose.ui.graphics.drawscope.DrawScope, but class was expected (declaration of 'androidx.compose.ui.graphics.drawscope.DrawScope'
proj lever build.gradle:
plugins {
    id 'com.android.application' version '8.1.1' apply false
    id 'com.android.library' version '8.1.1' apply false
    id 'org.jetbrains.kotlin.android' version '1.8.22' apply false
app level:
composeOptions {
        kotlinCompilerExtensionVersion "1.4.8"
  def composeBom = platform('androidx.compose:compose-bom:2023.08.00')
    implementation composeBom
    androidTestImplementation composeBom
    implementation 'androidx.compose.material:material'
    implementation 'androidx.compose.ui:ui-tooling-preview'
    debugImplementation 'androidx.compose.ui:ui-tooling'
    implementation("io.intercom.android:intercom-sdk:15.2.2")
Hi @mishmax !
Issues like this are best taken up with our Support team. That way they can easily request specific details around the situation. I’ll go ahead and send this conversation their way so they can take a look. You should hear from them via the email that you signed up with!
  • October 1, 2023
Hi @mishmax !
