Hi,
We upgraded the Intercom SDK on react-native to 5.1.1, however we found a very strange crash. On a screen we use https://github.com/react-native-picker/picker and when the picker is opened on Android the app will crash. We found that the Intercom upgrade from 4.0.1 to 5.1.1 was the culprit. I presume it’s something to do with the underlying Android SDK which was updated. Below is the stack trace from Sentry
java.lang.ClassNotFoundException: androidx.appcompat.widget.e0$a
at androidx.appcompat.widget.e0.setSelector(DropDownListView.java:1)
at android.widget.AbsListView.<init>(AbsListView.java:899)
at android.widget.ListView.<init>(ListView.java:231)
at android.widget.ListView.<init>(ListView.java:227)
at androidx.appcompat.widget.e0.<init>(DropDownListView.java:1)
at androidx.appcompat.widget.i0.s
at androidx.appcompat.widget.i0.q(ListPopupWindow.java:4)
at androidx.appcompat.widget.i0.a(ListPopupWindow.java:1)
at androidx.appcompat.widget.w$e.l(AppCompatSpinner.java:4)
at androidx.appcompat.widget.w.b
at androidx.appcompat.widget.w.performClick(AppCompatSpinner.java:3)
at com.reactnativecommunity.picker.h.performClick(ReactPicker.java:4)
at android.view.View.performClickInternal(View.java:7418)
at android.view.View.access$3700(View.java:835)
at android.view.View$PerformClick.run(View.java:28681)
at android.os.Handler.handleCallback(Handler.java:938)
at android.os.Looper.loopOnce(Looper.java:201)
at android.os.Looper.loop(Looper.java:288)
at android.app.ActivityThread.main(ActivityThread.java:7894)
at com.android.internal.os.RuntimeInit$MethodAndArgsCaller.run(RuntimeInit.java:548)
at com.android.internal.os.ZygoteInit.main(ZygoteInit.java:1009)
java.lang.NoClassDefFoundError: Failed resolution of: Landroidx/appcompat/widget/e0$a;
