Build error using Xcode 12.5 | Community
  • May 31, 2021
  • 51 views
After installing Intercom SDK using CocoaPods I get a build error trying to run my app on a physical device (on the iOS simulator everything works fine).
The error I get is:
building for iOS, but linking in dylib file (/Users/zivnergal/Library/Developer/Xcode/DerivedData/MishlohaDeliveryApp-axgsnxqfnywcgrevkhngnimsxuzw/Build/Products/Debug-iphoneos/Intercom.framework/Intercom) built for iOS Simulator, file '/Users/zivnergal/Library/Developer/Xcode/DerivedData/MishlohaDeliveryApp-axgsnxqfnywcgrevkhngnimsxuzw/Build/Products/Debug-iphoneos/Intercom.framework/Intercom' for architecture arm64
Anyone faced this issue?
@user603​ , the Best way to fix this or get more information is to Contact the Intercom Engineer support team via Messenger.
  • June 1, 2021
Hey @ziv n​, which version of our iOS SDK are you using? Xcode should work OK from version 9.0 onwards.
  • June 8, 2021
I have same problem
Xcode 12.5 and last version of Intercom SDK.
06/08/2021
  • June 8, 2021
Can you help?
  • June 8, 2021
