didRegisterForRemoteNotificationsWithDeviceToken called twice with Intercom iOS SDK | Community
  • March 21, 2024
  • 282 views
Please, do not call UIApplication.shared.registerForRemoteNotifications() inside Intercom iOS SDK.
This causes application(_:didRegisterForRemoteNotificationsWithDeviceToken:) to be called twice if you call registerForRemoteNotifications when you need in you app.
I can’t disable this. Also IntercomAutoIntegratePushNotifications: NO don’t disable registerForRemoteNotifications() call.
Hey there @e.vandyshev !
This topic is best discussed with our Support Team. I’m going to send you in their direction. They will reach out to you via the Email that you currently have on file to discuss this with you further. Be on the lookout for their response.
  • March 26, 2024
Reproducible on latest Intercom iOS SDK version 16.6.1
  • March 31, 2024
