Displaying of collections seems broken in react-native-intercom | Community
Hey,
After migrating from
"@intercom/intercom-react-native": "^3.0.5",
to latest version
"@intercom/intercom-react-native": "^4.0.1",
the displaying of specific helpcenter collections does not work anymore.
Old code: Does not work after updating the SDK
const res = await Intercom.displayHelpCenterCollections([‘1234567’])
// true
New code: Also does not work with the latest SDK
const collections = await Intercom.fetchHelpCenterCollections();
    "id": "1234567",
    "title": "FAQ"
const collectionIds = collections.map(_ => _.id);
// [ "1234567" ]
const collectionContent = IntercomContent.helpCenterCollectionsWithIds(collectionIds);
  "type": "HELP_CENTER_COLLECTIONS",
  "ids": [
    "1234567"
const res = await Intercom.presentContent(collectionContent);
// true
The problem is the same for both methods:
displayHelpCenterCollections and presentContent return true, but no Intercom popup is opened.
Best answer by Daniel M15
Hey @Thilo! Daniel from Customer Support Engineering here 🔧
It seems like there may be an issue with this functionality in React. We may require some sensitive information from you to thoroughly investigate this, so we will escalate your case to our Messenger support team. In the meantime, can you try reverting to the older version of the SDK that was working for you? Thanks!
Daniel M15
  • 240 replies
  • April 26, 2023
Hi ​@Daniel M15, this is still the case with the iOS SDK for react native. It works as expected on Android though
  • March 24, 2025
How can this possibly still be unfixed? Opening a new issue for awareness.
(This is an Intercom iOS SDK issue, nothing to do with the RN wrapper)
