Intercom android sdk crashing - Jetpack compose 1.7 - BOM v2024.09.00 ~ Intercom 15.10.2 | Community
  • September 13, 2024
  • 166 views
2024-09-05 11:40:09.795 4736-4736 AndroidRuntime ipnossoft.rma.free E FATAL EXCEPTION: main
Process: ipnossoft.rma.free, PID: 4736
java.lang.NoSuchMethodError: No static method rememberModalBottomSheetState(ZLkotlin/jvm/functions/Function1;Landroidx/compose/runtime/Composer;II)Landroidx/compose/material3/SheetState; in class Landroidx/compose/material3/ModalBottomSheet_androidKt; or its super classes (declaration of 'androidx.compose.material3.ModalBottomSheet_androidKt' appears in /data/app/~~g_FRDbFowwX3NIDZuLr61w==/ipnossoft.rma.free-uVLziORaSPfDo1O1hhh66A==/base.apk)
at io.intercom.android.sdk.m5.conversation.ui.ConversationScreenKt.ConversationScreenContent(ConversationScreen.kt:370)
at io.intercom.android.sdk.m5.conversation.ui.ConversationScreenKt.ConversationScreen(ConversationScreen.kt:186)
at io.intercom.android.sdk.m5.navigation.ConversationDestinationKt$conversationDestination$12.invoke(ConversationDestination.kt:166)
at io.intercom.android.sdk.m5.navigation.ConversationDestinationKt$conversationDestination$12.invoke(ConversationDestination.kt:102)
at androidx.compose.runtime.internal.ComposableLambdaImpl.invoke(ComposableLambda.jvm.kt:139)
at androidx.compose.runtime.internal.ComposableLambdaImpl.invoke(ComposableLambda.jvm.kt:35)
at androidx.navigation.compose.NavHostKt$NavHost$14$1.invoke(NavHost.kt:308)
at androidx.navigation.compose.NavHostKt$NavHost$14$1.invoke(NavHost.kt:306)
at androidx.compose.runtime.internal.ComposableLambdaImpl.invoke(ComposableLambda.jvm.kt:109)
Upgrading gave us some class not found errors coming from Intercom. Do you guys have to keep using experimental apis? It is frustrating to be blocked from updating because of your sdk.
Jetpack compose 1.7.0 is a big update and allows animations for adding and removing items from lazy collections. Please release an update as soon as possible, thanks!
H @Sean Blahovici, It’s Mat from the Support Engineering Team 😀
Version 15.10.3 of our Android SDK was released last week and contains support for Compose 1.7.0.
Hope this helps
  • September 23, 2024
Related:
Hope this helps
