Intercom crashes using Android SDK 15.11.2 on when attempting to open a chat or start a new chat | Community
  • December 4, 2024
  • 154 views
I recently updated my intercom version from v15.10.0 to v15.11.2 because my app started to crash whenever a user tries to type a message. After upgrading, my app crashes whenever a user opens a chat or tries to start a new chat
Error log for v15.10.0
java.lang.IllegalArgumentException: offset(1) is out of bounds [0, 0]
        at androidx.compose.ui.text.MultiParagraph.requireIndexInRangeInclusiveEnd(MultiParagraph.kt:913)
        at androidx.compose.ui.text.MultiParagraph.getCursorRect(MultiParagraph.kt:748)
        at androidx.compose.ui.text.TextLayoutResult.getCursorRect(TextLayoutResult.kt:553)
Error log for v15.11.2
java.lang.IllegalArgumentException: no paragraph (layoutCache=ParagraphLayoutCache(paragraph=null, lastDensity=InlineDensity(density=2.8125, fontScale=1.0)), textSubstitution=null)
        at androidx.compose.foundation.text.modifiers.TextStringSimpleNode.draw(TextStringSimpleNode.kt:418)
        at androidx.compose.ui.node.LayoutNodeDrawScope.drawDirect-eZhPAX0$ui_release(LayoutNodeDrawScope.kt:110)
        at androidx.compose.ui.node.LayoutNodeDrawScope.draw-eZhPAX0$ui_release(LayoutNodeDrawScope.kt:89)
        at androidx.compose.ui.node.NodeCoordinator.drawContainedDrawModifiers(NodeCoordinator.kt:450)
        at androidx.compose.ui.node.NodeCoordinator.draw(NodeCoordinator.kt:439)
        at androidx.compose.ui.node.LayoutModifierNodeCoordinator.performDraw(LayoutModifierNodeCoordinator.kt:280)
        at androidx.compose.ui.node.NodeCoordinator.drawContainedDrawModifiers(NodeCoordinator.kt:447)
        at androidx.compose.ui.node.NodeCoordinator.access$drawContainedDrawModifiers(NodeCoordinator.kt:58)
        at androidx.compose.ui.node.NodeCoordinator$drawBlock$1$1.invoke(NodeCoordinator.kt:469)
        at androidx.compose.ui.node.NodeCoordinator$drawBlock$1$1.invoke(NodeCoordinator.kt:468)
        at androidx.compose.runtime.snapshots.Snapshot$Companion.observe(Snapshot.kt:503)
        at androidx.compose.runtime.snapshots.SnapshotStateObserver$ObservedScopeMap.observe(SnapshotStateObserver.kt:502)
        at androidx.compose.runtime.snapshots.SnapshotStateObserver.observeReads(SnapshotStateObserver.kt:258)
        at androidx.compose.ui.node.OwnerSnapshotObserver.observeReads$ui_release(OwnerSnapshotObserver.kt:133)
        at androidx.compose.ui.node.NodeCoordinator$drawBlock$1.invoke(NodeCoordinator.kt:468)
        at androidx.compose.ui.node.NodeCoordinator$drawBlock$1.invoke(NodeCoordinator.kt:466)
        at androidx.compose.ui.platform.GraphicsLayerOwnerLayer.drawLayer(GraphicsLayerOwnerLayer.android.kt:271)
        at androidx.compose.ui.node.NodeCoordinator.draw(NodeCoordinator.kt:434)
        at androidx.compose.ui.node.LayoutNode.draw$ui_release(LayoutNode.kt:1000)
        at androidx.compose.ui.node.InnerNodeCoordinator.performDraw(InnerNodeCoordinator.kt:196)
I am using the exact compose setup in my build.gradle just like in the sample app
    def composeBom = platform("androidx.compose:compose-bom:2024.10.01")
    implementation composeBom
    implementation "androidx.compose.ui:ui"
    implementation "androidx.compose.material3:material3"
    implementation "androidx.compose.ui:ui-tooling-preview"
    debugImplementation "androidx.compose.ui:ui-tooling"
Best answer by Milan
@michael_leap as this seems to be urgent issue I suggest going through the official Intercom support (chat) and stating how urgent this is for you.
Milan
  • 310 replies
  • December 5, 2024
Erin
  • 46 replies
  • December 7, 2024
This is a very complex problem. you need official Intercom support. Contact them.
Have You got any solution for the above problem ?. iam facing similar issue ​@michael_leap
Hi all!
This issue should have been fixed in the new versions of the Android SDK.
Could you update and see if the issue persists?
