Intercom SDK for iOS platform is not working... and it is not working only on production environment because on staging everything work well. Is something working wrong with the SDK?
Intercom iOS SDK is not working
Best answer by Daniel M15
Hey @alexandru​ and @samuel b​! Daniel from Customer Support Engineering here 🔧
It sounds like you could be making your request using the authentication keys and/or the Identity Verification secret keys that are associated your Test environment. Please note that your main workspace uses a different set of keys for both. Can you please check that you are using the keys from your production app in the Developer Hub and, if you've got Identity Verification enabled, the secret keys from the production workspace in Intercom?
If this is not the issue, would you mind bringing this one to our support team via the Intercom Messenger? It's possible that this may take some investigating from a Support Engineer.
Thank you 🙌
Join the Intercom Community 🎉
Login to the community
