iOS build error using @intercom/intercom-react-native with Expo SDK 53 (React Native 0.79) | Community
  • May 7, 2025 2:24 AM UTC
  • 692 views
Hello
After upgrading my app to Expo SDK 53 (React Native 0.79), the iOS build fails when using @intercom/intercom-react-native.
Error message:
❌  (ios/Tikin/AppDelegate.swift:1:2)
> 1 | #import <IntercomModule.h>
    |  ^ no macro named 'import'
  2 | import Expo
  3 | import React
  4 | import ReactAppDependencyProvider
› 1 error(s), and 3 warning(s)
This line appears in the generated AppDelegate.swift:
But #import is not valid in Swift files — this causes the build to fail.
Environment:
  • Expo SDK: 53
  • React Native: 0.79
  • @intercom/intercom-react-native version: [insert version if known]
  • Build: EAS Build for iOS
It seems the native module is injecting Objective-C code (#import) into a Swift file. Is there an update or change needed for compatibility with SDK 53 and RN 0.79?
Best answer by Paul Byrne
Hey ​@Hisham Nimri can you open a conversation through the messenger and reference our chat here. We have an open issue (382798) for this that we can add you to.
  • May 14, 2025 12:05 AM UTC
getting the same error
Adding to this, same problem.
  • May 16, 2025 3:29 AM UTC
I'm having basically the same issue:
❌  (ios/myExpoProject/AppDelegate.swift:3:8)
  1 | import Expo
  2 | // @generated begin Intercom header - expo prebuild (DO NOT MODIFY) sync-3ff58f63b24eba463250844e4b0439beea83a5cc
> 3 | import intercom_react_native.IntercomModule
    |        ^ no such module 'intercom_react_native.IntercomModule'
  4 | // @generated end Intercom header
  5 | import React
  6 | import ReactAppDependencyProvider
If I modify it manually to import intercom_react_native then it runs fine, but that's auto generated by expo prebuild.
Paul Byrne
  • May 17, 2025 11:25 AM UTC
Hey ​@Paul Byrne, can we have access to the issue?
