Issue with receiving push notification in android. | Community
  • Jan 10, 2022 12:49 PM UTC
  • 412 views
We are using expo notification package for push notification in our project. When we add the intercom react native push notification android code changes that are provided in the documentation we are getting intercom notification but our existing push notification are not coming. Is there any way to use both. Kindly suggest us. Thanks in advance
Best answer by Eric Fitz
Apologies for the delay in my response @sivakumar​. I'd recommend that you contact our Support Engineers directly about this via the Messenger in your Intercom workspace.
  • Jan 11, 2022 12:19 PM UTC
Hey @sivakumar​, when you say "our existing push notification" do you mean outbound push notifications that you are sending to your customers?
  • Jan 11, 2022 12:31 PM UTC
These are push notification that are not related to Intercom.
  • Jan 12, 2022 5:37 PM UTC
OK, just so I understand, your issue is that installing Intercom caused push notifications in your other system to stop working?
  • Jan 13, 2022 5:46 AM UTC
Yes you’re right, after adding the below code in android as mentioned in the intercom documentation.
<!-- Add xmlns:tools to manifest. See example below-->
<manifest
xmlns:tools="http://schemas.android.com/toolsquot;
<application>
<activity>
</activity>
<!-- START: Add this-->
<service
android:name=".MainNotificationService">
<intent-filter>
<action android:name="com.google.firebase.MESSAGING_EVENT"/>
</intent-filter>
</service>
<receiver
android:name="com.intercom.reactnative.RNIntercomPushBroadcastReceiver"
tools:replace="android:exported"
android:exported="true"/>
<!-- END: Add this-->
</application>
</manifest>
  • Jan 19, 2022 11:06 AM UTC
