Missing required reason for accessing file timestamp in iOS SDK privacy manifest? | Community
  • April 9, 2024
  • 215 views
When submitting our app to App Store Connect I am still receiving some warnings about missing required reasons. Using the binary-based scanner script located here I am seeing the following:
Used symbols in binary ./Debug.app/Frameworks/Intercom.framework/Intercom: NSFileCreationDate, NSFileModificationDate, NSFileSystemFreeSize, NSFileSystemSize, NSURLContentModificationDateKey, NSURLCreationDateKey, NSUserDefaults, stat
Looking at the Intercom PrivacyInfo.xcprivacy as of version 17.0.0 I see entries for UserDefaults and SystemBootTime, but not FileTimestamp even though the script shows there are references within the framework to NSFileCreationDate, NSFileModificationDate, NSURLContentModificationDateKey, NSURLCreationDateKey and stat.
Is this something you are aware of? Do you intend to add the appropriate reason to your privacy manifest?
Hey there @Hallow Developers!
Just a heads up that it looks like the issue around this Privacy manifest was fixed in version 17.0.2 of the iOS SDK!
bernice
  • Expert User ✨
  • April 15, 2024
Hey @Hallow Developers 👋 Given the nature of this query and that we’ll likely need some further details here, I’m going to pass this over to the team as a Conversation to take further action on this issue for you. You’ll get a response from us via the Messenger in your workspace 💬
  • April 21, 2024
