My mobile push is not arriving to my Android device. | Community
Question
  • September 23, 2022
  • 54 views
Hi, i am sending a test push notification to my mobile phone. I did all the steps and the notification appears as sent at intercom ui but i never arrived to my mobile phone (android).
My app is build with react native and the device token is well capturetest-intercom
Daniel M15
  • September 27, 2022
Hey @rodrigo c​! Daniel from Customer Support Engineering here 🔧
Can you please confirm that:
  1. Notifications are not disabled for your app on your test device? On the device, go to Settings > Sound & Notification > App notifications. This may differ depending on the Android version.
  2. You have specified the correct Push Server API key?
  3. You have added your "google-services.json" file in the correct directory?
If you are still experiencing issues after checking these, please reach out to us via our Messenger. Thanks!
