[SDK] [iOS] [Swift] [Crash] Intercom 13 and 14 crashes
Hello, Intercom team.
I've encountered a serious problem when using Intercom ios sdk on the latest versions of ios 16.4 and higher, the application began to crash with an error when trying to open a conversation from the list of conversations in Intercom. (1)
After that, I tried to update Intercom version to 14.1.0 but faced an even more serious problem, the application began to crash when opening the Intercom screen (after calling Intercom.presentMessenger()), including on older iOS versions. (2)
Are you aware of these problems and can you suggest a solution?
1)
Xcode Version 14.3 (Swift)
iPhone iOS versions 16.4 and 16.4.1
Intercom iOS SDK version 13.0.0 (installed with cocoapods)
Error description:
Thread 1: "Invalid batch updates detected: the number of sections and/or items returned by the data source before and/or after performing the batch updates are inconsistent with the updates.\nData source before updates = { 1 section with item counts: [1] }\nData source after updates = { 1 section with item counts: [1] }\nUpdates = [\n\tInsert item (0 - 0)\n]\nCollection view: <IntercomSDKPrivate.TouchTransparentCollectionView: 0x15e328000; baseClass = UICollectionView; frame = (-375 0; 375 627); transform = [1, 0, 0, 1, -375, 0]; clipsToBounds = YES; alpha = 0; gestureRecognizers = <NSArray: 0x6000022d8cf0>; backgroundColor = UIExtendedGrayColorSpace 0 0; layer = <CALayer: 0x600002cc6dc0>; contentOffset: {0, -56}; contentSize: {375, 513}; adjustedContentInset: {56, 0, 0, 0}; layout: <ICMHomescreenFlowLayout: 0x15d016520>; dataSource: <ICMHomescreenViewController: 0x15d8d0200>>"
2)
iPhone iOS versions 15.*, 16.*
Intercom iOS SDK version 14.0.0 and 14.1.0 (installed with cocoapods)
Error description:
Thread 1: "[<IntercomSDKPrivate.HomeHeaderViewController 0x15995b000> setValue:forUndefinedKey:]: this class is not key value coding-compliant for the key bannersView."
Best answer by Racheal
Hey @gleb.preger Racheal from the support engineer team here👋
I think I reached out to you about this in your conversation with support and you said you’ve solved it! If not feel free to reach back out and we can dive back into it.
  • 512 replies
  • May 8, 2023
  • May 10, 2023
Hi, we have not discussed this problem in a conversation and it is still not resolved.
  • May 15, 2023
I found the cause of the crash in versions 14 and 15. IntercomSDKPrivate.HomeHeaderViewController tries to use HomeHeaderView.xib from the main application bundle (if it exists) and not from the Intercom module. Enough to reproduce the crash- create an empty project- install Intercom pod- create a HomeHeaderView.xib file in the project- call Intercom.present() at application startup.And you will get a crash with the description:*** Terminating app due to uncaught exception 'NSInternalInconsistencyException', reason: '-[UIViewController _loadViewFromNibNamed:bundle:] loaded the "HomeHeaderView" nib but the view outlet was not set.'
Brian B11
  • 40 replies
  • June 23, 2023
Hi everyone, thanks for reporting this issue.
Its been fixed in Release 15.0.1 of the iOS SDK.
  • July 14, 2023
We are still experiencing this crashing issue on the latest intercom-cordova plugin. Any idea if this was updated with a fix or if it will be soon?
