Using intercom with Expo | Community
  • August 1, 2023
  • 6 replies
  • 2854 views
Hi Intercom
I installed @intercom/intercom-react-native with my expo sdk, working on iOS.
I used expo prebuild to be able to add intercom following the installation instruction provided for iOS, and it’s working correctly using iOS simulator or a dev environment.
But when we distributed the release using Testflight, the app crash while initializing Intercom. It is not happening when we deactivate intercom.
Please find below my settings :
Package.json
"dependencies": {
"@expo/webpack-config": "^0.17.2",
"@gorhom/bottom-sheet": "^4",
"@hookform/resolvers": "^2.9.10",
"@intercom/intercom-react-native": "^5.1.0",
"@notifee/react-native": "^7.8.0",
"@react-native-async-storage/async-storage": "^1.17.11",
"@react-native-community/datetimepicker": "6.5.2",
"@react-native-firebase/app": "18.0.0",
"@react-native-firebase/messaging": "18.0.0",
"@react-navigation/material-bottom-tabs": "^6.2.15",
"@react-navigation/native": "^6.1.1",
"@react-navigation/native-stack": "6.6.1",
"@reduxjs/toolkit": "^1.9.1",
"@shopify/flash-list": "1.3.1",
"@shopify/react-native-skia": "0.1.192",
"@types/react": "~18.0.24",
"@types/react-native": "~0.70.6",
"axios": "1.2.1",
"config-plugin-react-native-intercom": "^1.10.1",
"date-fns": "^2.29.3",
"expo": "~47.0.14",
"expo-build-properties": "~0.4.1",
"expo-camera": "~13.1.0",
"expo-dev-client": "~2.0.1",
"expo-image-picker": "~14.0.2",
"expo-splash-screen": "~0.17.5",
"expo-status-bar": "~1.4.2",
"expo-system-ui": "~2.0.1",
"expo-updates": "~0.15.6",
"i18n": "^0.15.1",
"i18next": "^21.9.2",
"intl": "^1.2.5",
"luxon": "^3.2.1",
"react": "18.1.0",
"react-dom": "18.1.0",
"react-hook-form": "7.44.3",
"react-i18next": "^11.18.6",
"react-native": "0.70.8",
"react-native-animated-splash-screen": "^2.0.5",
"react-native-dotenv": "^3.4.7",
"react-native-gesture-handler": "~2.9.0",
"react-native-gifted-chat": "^2.0.1",
"react-native-otp-textinput": "^1.0.1",
"react-native-paper": "^5.8.0",
"react-native-reanimated": "~3.1.0",
"react-native-render-html": "^6.3.4",
"react-native-safe-area-context": "4.5.1",
"react-native-screens": "~3.20.0",
"react-native-signature-canvas": "^4.5.0",
"react-native-skia-gesture": "^0.1.7",
"react-native-svg": "13.4.0",
"react-native-vector-icons": "^9.2.0",
"react-native-web": "~0.18.9",
"react-native-webview": "11.23.1",
"react-native-wheely": "^0.6.0",
"react-redux": "^8.0.5",
"styled-components": "^5.3.6",
"thenby": "^1.3.4",
"typescript": "^4.6.3",
"yup": "^0.32.11"
"devDependencies": {
"@babel/core": "^7.12.9",
"@babel/plugin-proposal-export-namespace-from": "^7.18.9",
"@changesets/cli": "^2.26.0",
"@types/luxon": "^3.2.0",
"babel-plugin-module-resolver": "^4.1.0",
"babel-plugin-transform-inline-environment-variables": "^0.4.4",
"eslint": "^7.20.0",
"eslint-config-airbnb": "^18.2.1",
"eslint-config-prettier": "^8.3.0",
"eslint-import-resolver-typescript": "^2.4.0",
"eslint-plugin-i18next": "^6.0.0-2",
"eslint-plugin-import": "^2.22.1",
"eslint-plugin-jsx-a11y": "^6.4.1",
"eslint-plugin-prettier": "^4.0.0",
"eslint-plugin-react": "^7.22.0",
"eslint-plugin-react-hooks": "^4.2.0",
"eslint-plugin-react-i18n": "^1.0.3",
"eslint-plugin-unused-imports": "^1.1.5",
"i18next-scanner": "^4.0.0",
"prettier": "2.2.1",
"swagger-typescript-api": "^12.0.2"
"resolutions": {
"@babel/core": "^7.20.2",
"babel-loader": "^8.3.0"
"private": true
podfile:
  - Intercom (15.0.1)
- intercom-react-native (5.1.1):
- Intercom (~> 15.0.0)
- React-Core
javascript
import { useEffect, useState } from 'react'
import Intercom, { UserAttributes } from '@intercom/intercom-react-native'
import AsyncStorage from '@react-native-async-storage/async-storage'
export const useIntercom = (intercomUser?: UserAttributes, enabled: boolean = true) => {
const connect = async () => {
try {
await Intercom.logout()
const response = await Intercom.loginUserWithUserAttributes(intercomUser)
console.log('call intercom', response)
setIsConnected(response)
Intercom.getUnreadConversationCount().then((value) => {
console.log('new message from intercom', value)
setUnreadMessages(value)
} catch (error) {
console.log('error', error)
useEffect(() => {
if (isConnected) {
console.log('intercom connected')
return
if (enabled) {
connect()
}, [intercomUser, isConnected, enabled])
And here is the log error
its only happening when intercom is activate, if not, the app works correctly.
Can you help us on this, thanks in advance for your help
Best answer by Racheal
Hey David Racheal from the support engineer team here👋
Issues like these are best handled 1:1 so we can take a better look at your workspace settings. I’ve gone ahead and forwarded this into our support team to help you out!
  • August 2, 2023
Hello,
I would appreciate some help on this issue, or does someone had the same problem ?
Thanks a lot
  • August 4, 2023
Bump
  • August 8, 2023
  • August 8, 2023
thanks @Racheal
Lets settle a meeting soon, your help will be very usefull !
Will you PM me ?
Thanks a lot
  • February 10, 2024
I was able to integrate intercom with my expo 50 app by writing my own custom plugin. Here is a minimal repo with the mod-plugin.
  • March 18, 2024
Hi @rxjucse I am getting error while submitting app on appstore
ITMS-90683: Missing purpose string in Info.plist
