How to show a post to all visitors that are not logged in? | Community
  • March 17, 2021
  • 86 views
Hello! I'm creating a series to send a promotional campaign.
I send specific emails to users based on different factors but I'd also like to show a post "popup" to all visitors that aren't logged in.
Is there a way of achieving that?
Best answer by Kevin Bendixen
@mkt​ You can choose if you want rules to apply to users, leads or visitors. Pair that with the option to continue a path when certain rules are not matched and you should be good to go
Kevin Bendixen
  • March 19, 2021
Thanks a lot Kevin. Still struggling to find rules that help me exclude logged in users.
Do you know of a filter to exclude users that are online? I thought "Last seen" would do the trick but the minimum is last seen 1 day ago and that's too much. Last seen 0 days ago, doesn't work.
The idea is to show a post to non-logged in users only.
Thanks!2021-03-19_18-35-08
Kevin Bendixen
@mkt​ That's hard to answer without knowing your case. For example, we are providing a web app and so logged-in users will access specific URLs. That way you could show a message to users if the current URL does not contain "app."
Maybe you could also use the URL for your case
