Line breaks in Messenger Special Notice & changes not live after setting live. | Community
  • August 28, 2023
  • 178 views
Is there any ability to add line breaks in the Messenger settings > Special Notice:
Seems like Intercom doesn’t allow them: the line break has been added on the left but is not respected on the right,
Also, after clicking ‘Save and set live’, the changes are not live.
Is there a delay before the changes are live?
The Cloudflare cache has been cleared, but a hard refresh and incognito do not show the changes.
Best answer by Jennifer K
Hi @doig-mm
Jennifer here from Intercom
It's currently not possible to add line breaks in the special notice but I can flag this as a feature request for you 🚀
There should not be any delay when the changes are set live unless you are already in the Messenger.
  • August 29, 2023
Hi @doig-mm
  • September 1, 2023
I’m experiencing the same issue of the message not appearing after being set live. What trouble shooting steps should I go through to get the notice to work?
