Scroll on product tour? | Community
  • December 11, 2022
  • 188 views
Is there a way to scroll on the product tour? A couple items on my tour require scrolling to the right to make it work
@Naama Eisenreich, It’s Mat from the Support Engineering Team 😀
Form what you re saying it looks like you are trying to point your Tour Step towards the dynamic CSS element - it won't work. You need to choose another CSS selector in oder this Tour to work..
  • 512 replies
  • December 15, 2022
Hey @user2099​ Racheal from the support engineer team here👋
Are you looking for the Tour step itself to scroll to the right? If so, at the moment this isn't possible but a great idea for the @Product Wishlist​ ! Do you need to scroll to right because the image or content is too large? Any additional context on what this would ideally look like for you would be helpful!
  • December 16, 2022
Yeah, I was looking for it to scroll right or find the element out of view. I gave up on that step and just did the best I could.
I also have found launching the tour from the link does not work with the unique link either? I have another support question about that, but I would appreciate it if you had the answer.
@Racheal Im facing a similar issue - The element I want to point to is not presented on screen without scrolling.
Not only that - once the pointer appears (off screen) the screen cannot be scrolled so the user enters a tour limbo.
Is there’s a way around it?
