Users "not matched and removed from path" for no reason. Can someone help me to understand why ? | Community
  • February 18, 2021
  • 9 replies
  • 309 views
I have noticed in one series that some users leave a path "Not matched and removed from path" although they absolutely no reason to do so as the rules and exit rules of such path and series.
The path and series is pretty basic, only a suite of emails with entry rules, emails and wait tags in between.
I can't find any reasons for this happening in the help center.
Do you have an idea of what may happen ? Or informed about a bug ongoing ?
Thank you for your help
@user312​ , Oh... Thanks for clarifying.
Once you update the rule setting with "Try to match once" people are still removing from the path?
  • February 18, 2021
Hello @user312​ , Can you provide some screenshots?
  • February 19, 2021
Sure !
I have tried to illustrate the situation below
Onboarding
  • February 19, 2021
@user312​ , Try to match period is one day instead of Try to match once.1day
  • February 19, 2021
Ok, thank you for your quick response! I modified it and will monitor results.
I am not to understanding why this may be the root of the problem since the user passed successfully this step and it's on the email itself that it didn't went through. Any hints here ?
  • February 22, 2021
@user312​ , I ask about this case to @eric f11​ , and appears, Users who unsubscribed from email notifications get disengaged.
Can you check if users who get disengaged were unsubscribed from email notifications?
BTW - there should be some notification about this @Product Wishlist​ (Intercom product team should add some notification).
  • February 22, 2021
Thanks for the follow-up @roy s11​
I have checked but actually it appears the users have not unsuscribed...
  • February 22, 2021
  • February 22, 2021
So far I haven't noticed any removed from the path but will monitor over the coming days
  • September 8, 2022
One other reason could be a situation when a user has hard-bounced issues. In that case, they could pass through the 1st email step but then will be automatically disengaged (as the email server will return a deliverability error).
Screen Shot 2022-09-08 at 11.18.18 PM
