Why is my product tour having a delayed reaction and then getting stuck on one screen? | Community
  • March 8, 2021
  • 112 views
Building a product tour, I have created all the slides, but after the 3rd slide or pop up and click next, the correlating screen does not load, it stays on one screen for the remainder of the tour.
Best answer by Brent
Hey @heather w11​ ,
As Roy has mentioned - screenshots are key! Your best bet is to go in and edit your product tour and head to the screen that is not appearing. Sometimes the pointers can fall off the CSS, (especially if you're updating your app) which can be ca cause of this. You can then re-point, or fix up the issue.
  • March 8, 2021
Hi @heather w11​ , I hope you are doing well.
Can you share some screenshots or videos? That will be helpful to understand your case.
Brent
Super User ✨
  • Super User ✨
  • March 9, 2021
Hey @heather w11​ ,
