Can I add an email collector to Product Tours? | Community
  • March 22, 2022
  • 10 views
Is it possible to add email collectors in the product tours? If so, how can it be added? I haven't found any documentation about it. Thank you very much!
Best answer by Aparna
Hey @user1675​ ! It is not possible to add email collectors in the tour, but if you have a field on your website to collect the data then you can use the fillable filed option. Here is a screenshot of the same https://d.pr/i/hyIxx6. Would that work for you?
  • March 24, 2022
