Cannot re-use a field in custom reports? no ability to use and and or operators in custom reports? | Community
  • February 17, 2023
  • 67 views
I'm not seeing an option to re-use a field in a custom report. i.e. if I use the 'conversation' tag field in a custom report, I cannot use that field again in the report. my use case is if I want to find ticket containing multiple tags, I cant do it. anyone else run into this? having the capability to use 'and' and 'or' operators is something basic that any reporting system should have, I think - unless I'm missing something totally!
Best answer by Joseph S.
Hi @Monish Prem​ ​
Indeed, you can't use the same parameter more than once, but you can select more than value for the same parameter (If I understood correctly, this would serve in your use-case)
Joseph S.
Forum|alt.badge.img+6
  • Expert User ✨
  • February 17, 2023
Hi @Monish Prem​ ​
  • February 22, 2023
You are correct, Amber. I didn't realize that was possible for the 'custom' fields as well. Thank you, that helps!
