Why is "Show Suggestions" not generating any recommended Topics? I've added Topics manually, and the reporting works well, but Intercom isn't making any suggestions for Topics. | Community
  • March 12, 2021
  • 147 views
There is no shortage of conversations to mine, and I've given it a couple of days as the help material suggests it's an overnight process.
Best answer by Keerthi
Hey @alex m14​ That makes more sense. it is definitely strange that you're not seeing suggestions. I know that the condition for this is that you need several hundred conversations in Intercom for this to be available. But you already mentioned you have enough. Perhaps it is a ticket to raise with Intercom Support if you're meeting the criteria and still not seeing suggestions
Edit: Here's a useful group to report bugs @Intercom Bug Reports​  and this thread might give you a prompt response - https://forum.intercom.com/s/question/0D52G00004r30LdSAI/do-you-have-any-questions-for-the-product-team-behind-our-new-reporting-features-question-from-an-intercom-product-education-manager/p>
  • Super User
  • March 12, 2021
Hi @alex m14​ ,
Have you turned on 'Suggest Help Articles' in your Task Bot?
Screenshot 2021-03-12 144346
Kevin Bendixen
@alex m14​ Adding to @user368​ answer. Note that this feature only works for English articles at the moment.
  • March 12, 2021
Hi. Thanks @kevin b​  and @user368​. Sorry, I should've been clearer. My query is about Conversation Topics reporting. The report below should, by now, be recommending topics to explore. Show suggestions is toggled on, but no topic suggestions (light blue) are being generated - only those that I've added manually below (dark blue, text obscured).
screenshot
  • Super User
  • March 12, 2021
