Why aren't Resolution Bot unanswered questions appearing? | Community
  • August 9, 2022
  • 42 views
​By accessing the resolution bot section, I don't see unanswered questions. Also, if I try to answer a new question by searching for a highly used word, no result comes up. Do you know why?
Best answer by Racheal
Hey @user1375​
The team was investigating an issue with the Resolution Bot which was impacting:
* Conversational Topics
* Resolution Bot unanswered questions
* Resolution Bot curation (specifically, the ability to search for historical questions).
The issue has since been resolved and everything should be back up and running for you now! You can also read this note on our Status Page, here 👈
  • August 11, 2022
Hey @user1375​
  • August 12, 2022
Thank you @racheal​. The issue is now solved! Have a nice weekend
