How do I find my API secret? | Community
  • November 4, 2021
  • 862 views
Best answer by Bastien
Hi @dorian m​,
The API secrets are in your Developer Hub:
https://app.intercom.io/a/apps/_/developer-hub/app-packages/p>
Select an app or create one, then:
If you just want to use the API to access data in your own Intercom workspace, you're looking for your "Access Token". It's on the "Authentication" page for your app:
access-token
If you're building an app for other people, and you're setting up an OAuth flow, you're looking for a "Client ID" + "Client secret". They are on the "Basic Information" page for your app:
oauth
Everything about authentication is here: https://developers.intercom.com/building-apps/docs/authentication-types/p>
  • November 4, 2021
Hi @dorian m​,
access-token
oauth
