Is it possible to format numbers in HTML email templates? | Community
I am building an HTML email template to display a variety of statistics. The statistics are in different formats such as percents and currency values. Is it possible to format a decimal as a percent in an HTML Template?
Decimal Example:
Value: .9856
Display Value (in template): 98.56%
Currency Example:
Value: 4578.19
Display Value (in template): $4,578.19
Based on your provided documentation, the only way to format numbers appears to be as a decimal or integer. Are there other formats that are acceptable?
Hey ​@Antonia Villa 👋 Jacques here from Intercom Support. I hope all is well today!
You're correct that the templating engine currently supports |integer and |decimal filters for number formatting, as documented.
Unfortunately, there isn’t built-in support for percentage or currency formatting directly within Intercom’s templating syntax (e.g. there's no |percent or |currency filter at this time).
Here’s what you can do as a workaround:
  1. Pre-process the number before passing it into the template (e.g. multiply .9856 by 100 and format to two decimal places: 98.56)
  2. Then, append the % symbol manually in your template:
For currencies like $4,578.19, you’ll need to format the number (with commas and decimals) before passing it to the template and include the currency symbol in the value itself.
Diana Tripac
  • 163 replies
  • January 9, 2025
👀 Adding ​@Milan ​@Nathan Sudds  in case they have any ideas on that 💪
Jacques Reynolds
