Event metadata doesn't display in Custom Bots | Community
  • February 4, 2022
  • 29 views
Hello, we've some problems displaying event metadata info in custom bots, it seems that the filters works fine but metadata not being displayed.
here are some screenshots which explain our situation.
user_event_metadatauser_event_custom_bot_config
user_event_app_chat
Has someone the same problem?
Thank you!
Best answer by Aparna
Hey @juan s​ ! Looks like a bug The best thing would be to contact our support team so they can investigate open up an issue if needed and update you on that.
  • February 9, 2022
  • February 9, 2022
@aparna​ Hello! I was talking with support team meanwhile and they reported the incidence, thank you!
  • February 9, 2022
  • April 1, 2022
Hello i have the same issue, is there a solution for this?
